Just an FYI there are new firmware updates for the SoloCinema XTR Sound Bar.
I just updated to R0201.
So if you own this Bar you should contact tech support & get the update.
If your having issues with the bar, the chance that a firmware fix can solve the problem is a good one, like all gear, you should always, update the firmware before ya dive in.
I was having freeze issues, where the bar would just freeze up on me & I would have to unplug the system to re boot it, so we'll see if this helps. otherwise the bar sounds fantastic.
