AVS › AVS Forum › Video Components › Video Download Services & Hardware › With HBO go now able to airstream, is it in 5.1?
post #1 of 8
Now that HBO go as Of today is able to airstream to my AppleTV, will it give me true 5.1 to the reciever,( Or only 2.0, that pro logic does its thing)
Thx
Edited by frostylou - 2/12/13 at 3:19pm
post #2 of 8
I'm also wondering if you can use the iPad's "interactive features" if you are streaming over Airplay.
In addition, to surround sound, is the video HD or standard def.
post #3 of 8
Thx
Hi frostylou, was watching Battleship on HBO Go from my iPhone 4s airplayed to apple tv ... it would start out at 2.0 then DD 5.1.
post #4 of 8
Cool to know. Thx JChin?
J..or anybody, Would you happen to know if it is actually Dolby digital plus. (The higher (640pbps) bitrate?
post #5 of 8
I didn't think airplay supported surround sound. Are you sure it's actually sending that to your receiver?
post #6 of 8
No DD +.
post #7 of 8
Hi xcrunner529, receiver (Denon 1909) showing 5.1 in and 5.1 out.
post #8 of 8
Ok. Thx
