AVS › AVS Forum › HDTV › HDTV Technical › Mounting standard antenna to DirecTV antenna
post #1 of 3
Hi,
I curently have my HD DirecTV antenna mounted on my roof. I bought a standard antenna. I am trying to find a bracket/mounting clamps which I can use it to mount my standard antena to the DirecTV antenna.. so I don't have to drill anything on my roof.
Can you recommend which ones you know ?
Edgar
post #2 of 3
Radio Shack usually has all the mounting hardware, but more importantly what kind of antenna did you get? Can you post your tvfool results so we can get an idea of reception in your area?
post #3 of 3
Hi,
Thanks for asking - I have following set
Antennas Direct ClearStream4 HDTV Antenna
40-Inch Antenna J-Mount, Mounting Hardware and Sealant Strips included
I installed this antenaa, mounted on this 40-in antenna J-Mount, then temporarily connected it to one TV with antenna inside the house. I am getting pretty good signals with just that try.
So right now I try to mount this set to my HD DirecTV antenna mounted on my house roof.
Edgar
  Back to Forum: HDTV Technical
