Hi, I want to buy 2 18" SI subs. I'm on a budget. I currently have an ep4000 and want to use it for these two subs.I dont know what would work best the D2 or D4s. I plan on purchasing some of flat packs from DIY Soundgroup. I am thinking two separate cabs to disperse the sound more evenly throughout the room. I don't listen to extremely loud levels. Usually -9 to -15 on my avr. I am not looking for bass no knock stuff off the wall,I just want my family and I to have the theater experience that will keep us at the edge of our seats if you know what I mean.
Room is 15x20x10 and leads into another small living room and open frames doors (if thats what you call them) to the kitchen area.
The issue- I currently have 2 Dayton HFs with 2 o audio 500w amps. I do not use the sub woofers because I cant get any sound from them LITERALLY!, THE 8'' SUBS ON THE Av123 Onix rs1000 sound louder than my 2 sealed 15s. I also get this very nasty and high pitched "POP" sound from them.Using Denon 4311 and tried audyssey but nothing worked
. I even moved the subwoofers to 3 different rooms in the house to see if it was that so called "house curved" or room issues but nothing worked.
Setup- Denon 4311 avr. Running a 14TB dedicated movie server using XBMC. Sony vw85 projector. Av123-rs1000 towers and RSC-200 (Big Foot) center channel, no surrounds yet
Finished product w/o subwoofers
BTW, selling the 1 Oaudio 500w plate amp basically never been used if any one wants to get one on their hands now that the company has gone out of business.
Edited by deathinc - 2/13/13 at 9:47am
. I even moved the subwoofers to 3 different rooms in the house to see if it was that so called "house curved" or room issues but nothing worked.Setup- Denon 4311 avr. Running a 14TB dedicated movie server using XBMC. Sony vw85 projector. Av123-rs1000 towers and RSC-200 (Big Foot) center channel, no surrounds yet
