Ok, so I'm having a bathroom added to the house and things in life have been super hectic up until now and I hadn't considered audio/video. Anyways, they are going to be putting up insulation and drywall tomorrow and I need to run wires today. I already have the wire here (cat6, rg6, and speaker). I'm definitely thinking of at least a stereo input speaker. I was going to put a speaker bracket in, but at this point, I think i'm just going to run the wire to the location and take a picture and after the drywall is up, cut the hole for the speaker (cheaper as well).
So, here is the bathroom (it is rough and probably not to scale, but it's ~11x9):
I drew circles were the light are going (I left out the 2 vanity lights and the one above the tub which will be a chandelier for the GF.) I figured a nice central spot for the speaker would be best. I am thinking I need to consider a wall volume control as well, but they've already run the electrical and I"m not sure where I would put it. Either way, it's in a place that I think I could easily add the switch later if I needed to.
As to video, looking at the picture above, does anyone have any suggestions for running the video portion? Please note that the walls that make up the shower are half walls with glass on top, The tub is really a claw foot, and the faucet for the tub is really on the wall between the shower and the tub.
Thanks in advance for any help you can provide.
I may have to run to home depot and get some wires to run and stash in the walls for now. Now on to your post:
