Hell all. I just bought Vizio E601-A3 and for the 1st time I am connect my tv with an HDMI cable directly out of the cable box and into the tv and sending the audio out of the tv via digital optical toslink to my sony 5.1 home theater. The problem I'm having is that the audio is slightly always behind on every station. From what I understand from various forums, it's usually the other way around ... the audio is usually ahead. This is driving me totally crazy. I've tried every possible audio setting on the cable box, the tv and the sony home theater. The tv has the latest firmware update, so that's not the problem. Here's the deal ... if I listen strictly to the sound from the tv and mute the sony 5.1, I'm seeing a "slight" delay. Not as bad, but it's there. When I go out of the optica from the tvl and into the sony, that delay gets slightly worse. Now, if I connect the digital audio out of the cable box and go directly into the sony 5.1, the delay is gone.
My question is this ..... is this a rarity or a somewhat common issue with audio AND video going together through HDMI? If it's the TV, I have a repair man coming out in a couple of days and my guess is that he'll probably swap it out for another since it's only a month old. If there's nothing I can do to remedy this problem, I may have to go with something like this....
http://www.amazon.com/gp/product/B00062NHTS/ref=s9_simh_gw_p23_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-3&pf_rd_r=0A1SFC92PGH12ZXV8D1Y&pf_rd_t=101&pf_rd_p=470938811&pf_rd_i=507846
so I can also hook up the audio output of my mac mini and the tv itself so i can use the internal apps like netflix, pandora, etc.
Any thoughts or suggestions would be welcome!
