I am seriously considering building a subwoofer using a JL Audio sub (or two). I see that JL has suggested box size for their subs in their website.... But when I punch in the speaker paramters in Bass Box Pro, the suggested cabinet sizes are way different. For example, the JL12W3v3-4 parameters from JL suggest a box that is 1.75 cu. ft. but bass box pro suggests a volume of 3.09 cubic ft from the TS parameters for a vented enclosure. On the other hand, for a sealed enclosure, JL suggest 1.125 cu. ft and Bass Box suggest a close 1.17 cu. ft. box which is close enough to be negligible.
Which parameters should I follow and why the differences?
