I have a older audio deck and that accepts 6 discrete channels (5.1) - no built-in decoder - L,R,SR,SL,C,Sub - and I have a Computer that has 3.5mm with discrete outputs 60ft physically apart (probably needs to be a 75ft cable) - It has on the back panel — "six connectors for 7.1 channel
support" - I want to run a cable between them that will connect the two of them. (giving up on wireless)
1) I've tried googling this and it seems difficult to google... There must be something simple to buy. -
2) Don't make me 'buy the farm' $expensive devices, or throw out my equipment... don't bother to post if that is your answer.
3) If you want me to use HDMI - how? to get the audio into the cable... my video card doesn't support it.
4) if you your asking about SPDIF, nope. My computer doesn't have it.
Basically I need 3-4?- 75ft stereo cables combined... - But it should be easier than that right?
