AVS › AVS Forum › Audio › DIY Speakers and Subs › statements spec?
statements spec? - Page 2
post #31 of 63
I think the requirements to hit reference are a little over stated. I have never seen a room big enough for the spl to actually drop 3db for every doubling of distance. It is much lower in my experience. The statements will get as loud as you need them to considering you are in an apartment. You would only need enough power to make sure the amp isn't clipping. I would look for quality here, not quantity. A Rotel AVR with 50w/channel would probably be all you need (as an example).
post #32 of 63
Originally Posted by Thomas 1966 View Post
I have a denon 3312 and the room is 17 x 19 x 8 ceiling I would maybe buy a xpa-2 emotiva 300 x 2 for the mains unless someone knows a better route best bang for the buck but still have good sound low fan noise long lasting etc I would run all other channels off the avr maybe a amp for the center I think 200 watts would be enough for the center I would buy the xpa-3 but it is only 200 x 3 anyone know of a amp rated 300 x 3 at 8 ohms under $1,000
If you want bang for your buck, then do like I did and go with a Behringer EP1,500 or even an EP4000. Those will net you a lot more power than the Emotiva, for less money.
post #33 of 63
I live in a house neighbors are all 100 feet or more away during respectable hours I close the windows and doors and crank it. I will try without an xtra amp first and then decide
post #34 of 63
I heard the fan noise was bad that you had to change the fan. How is the fan noise I would consider buying one I had seen them for like 275 before on amazon that would be good for me if the sq is as good as the emotiva and not too noisy with the fan
post #35 of 63
Yes, you have to do a fan mod on the EP series, but it is as simple as it gets.
post #36 of 63
wow checked out about the ep4000 I read 750 watts rms at 8 ohm pc for $275 I wonder just how much power the statements can handle I have been thinking maybe 250 rms with some peaks to about 400 thats just my guess does anyone know for sure that was the orginal question of this thread I really want to get a ep4000.maybe two run one channel to the center and one channel to a diy sub sounds like allot of people love the ep4000
post #37 of 63
get a much lower watt amp those speakers cant handle more then 100watt rms
post #38 of 63
that does not sound right to me statements have
17 watt rms tweeter
2 x 25 watt rms mids
2 x 80 watt rms woofers
seems like allot of speakers to be just 100 watt rms
my m 70s are 275 watts rms i think
I do not know the limits but I think you are right about ep4000 being over kill I will read about some lower models
I thought it was better to use a much larger amp than needed and only run it at half power or less
post #39 of 63
17 watt rms tweeter
Home audio and totally different from car audio. Rarely does the wattage rattings on a speaker actually mean that it can only take "x" number of watts. Using an EP4000 would work really well with the Statements, and the good thing about having that much power, is that you would have a sh*t load of head room, which will come in handy with dynamics and peaks in sound when watching movies or listening to music. Heck I have a bridged EP1500 running my single Ascend Acoustics Sierra-1 Center channel speaker and it works just fine. Having an EP4000 on the Statements would work no problem, what you have to worry about as far as blowing them up, is running too little power, not too much!
post #40 of 63
statements cc hooked up wow the detail is great I hear things like never before kill bill vol 1 I use for referance the fight scene with gogo with the chain so clear sounds like the chain is in the room so crisp
can turn up it is louder but does not sound louder just sounds like more. I am glad I started with the center that seems to have been my weekest link now I have to listen to everything I like again and am not in a big rush to replace my polk m 70s. yes center channel is the most important for ht . If not for AVS I would have never know anything about statements or HT in general
happy happy joy joy
post #41 of 63
Did you construct the Statement Center Channel crossover yourself? Or did someone else do it for you?
post #42 of 63
NIce! Glad you like it!
Money well spent.
post #43 of 63
constructed by meniscus
post #44 of 63
Well, based on your experience with your center channel and existing receiver, does it seem like you will have enough power without buying a new amp?
post #45 of 63
If that were true, you could blow your speakers by turning the volume down.
OP, glad you liked dealing with Meniscus Audio. They are a good outfit, I had a very positive experience with them.
Edited by djkest - 2/25/13 at 1:07pm
post #46 of 63
It is true, too little power is far worse than too much, due to over driven amps yeilding high levels of THD, clipping and other anomalies.
post #47 of 63
Only with the tweeters.
post #48 of 63
I do have enough but I worry about pushing the avr to hard for to long. center on avr will be ok but maybe get amp for mains someday a pro amp not sure wich one i should buy as behringer has several different amps I need to research for a while and the WAF.I will have to wait for xmass for a pro amp I think. The center is so clear crisp uncolored no distortion with much more detail as to what I hear. I will not ever need to up grade that is what I was looking for. good enough already with the center next the mains but no hurry because the polk m 70s sound ok with the new center. later the polks will be surrounds.
post #49 of 63
I wouldn't worry about pushing the receiver too hard. They are made to be beat on. It isn't a lifetime purchase anyway. There will be a new version of HDMI or some other interface, features, technology, etc coming down the road. You will want to upgrade it in a couple of years....
Just use it, it was designed that way. If you are not getting distortion and it is not shutting down, etc you are fine.
You probably have all the power that you need.
Like I said, I only have 100w and it will go louder than I could stand to listen to when used as a 5.1 system.
post #50 of 63
...the good thing about having that much power, is that you would have a sh*t load of head room...
That is only useful if you can use that much power. An EP4k will easily tear those speakers up before blinking the clip lights. Will you suddenly be in headroom nirvana with a 3000kW amp? No, you will just have a lot of wasted power, just like with the EP4k. I used my EP2500 to power a pair of Monitor Audio RS1 bookshelfs back in the day. It worked great, but it's not like I had ridiculous amounts of headroom because the speakers would blow before utilizing that power.
post #51 of 63
ok I got it back to what I thought I needed for my mains 250 watts rms rated at 8 ohms so something like 300 x 2 is what I will research
post #52 of 63
Try it first with your receiver!!!!!!!!
Your receiver will be an antique before it blows up from driving speakers too hard.
Edited by jpmst3 - 2/26/13 at 6:02am
post #53 of 63
if I push my avr harder and it gets to hot or something is it protected will a fail safe kick in? or does it just gets fried? at times I like to listen at +5db at times but I have always been afraid to go above 0db
I was curious and wanted to see how high it would go so just a second it went to +15 I did this a couple nights ago after telling me to push it harder so let me get this right + 15db( i did not think it would go that high) would take 10 times the power of +5db so +5 would be only a small fraction of power my avr is capable so +5 is safe? I also like music in muti stereo as it is allot louder but amp gets allot hotter. yes if I can run at +5db and be safe than yes I do not need an amp. I will hang out in amp forum and research this more. the $900 for this amp is allot for me I do need this amp to last awhile. Denon 3312 125 wpc
post #54 of 63
You can't just add the wattage ratings of the drivers together and assume that's how much power the speaker can take or require. For example, the woofers in the Statements will hit their excursion limits at 60 Hz with 80 watts per woofer (160 watts total). That number goes down depending on the frequency; for example, you would hit the excursion limits of the drivers at 40hz with only 80 watts total.
My big Krell amp will easily put out 300 watts per channel and while my main speakers Scan Speak drivers power ratings are as high or higher than the statement drivers they will be distorting below half that.
I would try a good receiver first and if that doesn't play loud enough for you, you could consider a larger amp or more efficient speakers.
Dennis
post #55 of 63
I am not sure why are so protective of your receiver. It's a consumer item made as bulletproof as possible. Crank the dang thing!
If you over do it, it will shut off. I have had many Denon, Onkyo, and Yamaha, receivers.
If you short the terminals, or overheat them, they shutdown. Wait a couple of seconds and power them back up.
I have only had it happen to me 3 or 4 times in 15 years, when I was pounding the crap out of them over the hot summer months during parties.
I have 3 receivers at the moment and have had dozens...I have never had a receiver go bad.
I have one in the garage in near 100% humidity all the time and one out in a work shed that goes from below 0 to 100 degrees F depending on weather and it always works.
I often drive 4 ohm loads with them and they still work fine.
post #56 of 63
ok I will relax some thanks I did not want to find out the hard way as my wife would be pissed and i bummed
and not allowed another avr for a long time. avr alone with out amp will be fine pushing it harder Thanks for your help I got the idea now
post #57 of 63
Dennis
Thanks for answering the origanal question I asked so I was not thinking the right way I am surprized that there is not more info out there on statements power handling I read about people using mono blocks with lots of power but never read how much power they are really using so I was thinking much more like the 300 watts a channel or something it would seem a upper level avr that rated like 145 wpc or so would be plenty than I will build alll my speakers year by year putting all my budget into building the statement towers and a good deep low sub knowing that buying a amp just will not make that big of a differance over my avr.also learned I can crank it more without killing it. only have a limited amount I can spend I have to get things right the first time around. If I did not have this avr forums I would be wasting all kinds of money never getting good sound and years to learn better if ever.I am on the right path now. time to let this thread die Thanks guys
post #58 of 63
The power handling numbers/excursion limits I mentioned are no different than any speaker, DIY or commercial, that doesn't have some sort of high pass filter either in the speaker itself or in the AVR's bass management. A $50k Magico or Wilson speaker will have similar limitations where they speaker will likely hit mechanical limits before thermal. It all comes down to how loud you want to listen to your speakers. Many here talk about the goal of hitting reference level with peaks of 105 db at the listening positions but most typical home audio speakers just aren't designed for that.
I want to clarify though; the Statements are an amazing sounding speaker. I heard Jim Holtz's first pair at his house long before they grew in popularity and they were one of the better sounding speakers I had ever heard...they still are. I can't imagine anyone not being happy with the sound. The Statements should play louder than most people would ever listen to them and sound great doing it. If your goal is great sound quality they are a very good choice.
Dennis
post #59 of 63
well here is what it looks like finished I now get to have a diy speaker avatar too.
post #60 of 63
red oak plywood from home depot used min wax pre-stain wood conditioner right before staining with red oak stain first time i ever used pre-stain will use it every time in the future.
Edited by Thomas 1966 - 3/4/13 at 9:05pm
