Originally Posted by Ethan Winer
The best place for a bass trap is wherever in the room bass builds up. This is usually in the corners, but the entire rear wall is also a good candidate. This short article and file download will help you find the best places for bass traps:
Pink noise aids placing bass traps
--Ethan
--Ethan
im curious: why do you recommend listening to identify areas of high pressure within the room (as our ears are sensitive to pressure), to subsequently place velocity-based porous LF absorbers?
