I've been taking a crash course on fire blocking lately, and I have a nagging question. The requirements, as I understand them, are to block vertical sections of wall from horizontal sections. Further, you have to provide blocking every 10' horizontally. Now, this gets a little tricky when you have a decoupled wall using clips and channel. For the connection between the walls and the ceilings, it's fairly simple. Hopefully Ted and John at the Soundproofing Company won't mind me posting their detail again
As long as you have something to run your first layer of ceiling drywall up to, you can caulk the edge and maintain your decoupling as well as provide fire blocking.
The part I don't understand, though, is how do you provide the blocking every 10' of horizontal wall space? You have a gap between your studs and the first layer of drywall on your wall that I don't see an easy way of filling without coupling your drywall to the wall.
I know one of their SIMs specifically mentions keeping the insulation off of the channel. Although, I really don't see any alternatives.
I'm not going to hold my breath, though
