Originally Posted by
tuxedocivic
What is it that we see in this example?
To me and the other member it was more obvious in person than the Screenies show. A very bright, vibrant image. Colors that do not appear shifted or off. Plenty of detail and sharpness. That despite the obvious specifications:
To my recollection, the Screen's actual "outside" Frame dimension was 130.5" x 56". The Spandex was wrapped completely over the outside edges of the fram]e. That actually makes the image as shown almost 143" diagonal, not the stated 135"er of the Thread Title. But the title does say what the end measurement of the Screen's diagonal size will be after the Trim is applied.(...inside dimensions 123" x 53" ) In the shown images, the image is zoomed out to fill every wee bit of real estate.
Temporary throw was at 15'. If the White / Light Silver Milliskin is 0.9 gain, then the foot lamberts would measure approx 15 fl.
0.8 gain? 13 fl. That latter level is the absolute bottom end of acceptable reflectivity for any screen that wants to be considered dynamic and vibrant....and that's "in the dark"
While not having access to equipment to make my own exacting measurements, I can relate from experience that the surface is NOT as low as 0.8 gain
As claimed, the surface texture was / is completely undetectable from just inches away.
I'm excited to see what milliskin can do because I have some coming. But not sure what this thread proves.
Than you miss the biggest points concerning how "normal" DIY'ers share info. They don't publish graphs....the don't post a White paper. The talk about what they choose, how they put it together, how happy (...or not...) they are about the end results, and lastly...if they have the camera and the skill set to know how to take shots that do in fact represent what they themselves see to be happening, then those shots are the final push many aspiring DIY'er need to have both the confidence needed to make a decision, and gain the impetus to get'ter dun. The posted results should be more than encouraging enough for someone considering White over Silver Milliskin Spandex screens that fall between 84" and 120" diagonal. The one above looks great at 140"+
Consider the normal arguments against screen shots. much is said....but darn...even the naysayers use those same shots to tout how good their set up is. go figure. When an Image is dim, if a camera compensates enough to raise brightness so that the image photographs better, the usual end results are blown out whites and little shadow detail. However if a image is properly metered and exposed, suddenly there is a photo replica of what the eye sees. Or....it shouldn't be posted, as good or bad, it's misleading.
Over the years, taking accurate shots was all DIY'er had to strut their stuff. It still is the primary application for doing so, but many are clueless as to what /how to do it.
That
IS changing....and you can tell by looking at the "Screen Shot Wars" threads. Use to was...only the SLR & DSLR crowd w/Mfg Screens could claim they had it down pat...and Boy... ya better not tell them THEIR shots were worthless or misleading !!
No...the real reasons behind Screenie haters are usually hidden from view. Jealousy....PO'edness because a DIY'er is showing such excellent results for little expenditure. Someone determined to find a way to dispute shown results. Etc, etc, etc.
But when time after time, one after another, good ol' basic Members get even the most basic instructions, and have decent DIY Screen at hand...the there comes the eye candy....and the wars are waged anew.
It is my experience understanding that yes...a camera can distort reality if improperly used. But I also know for certain that if someone knows how to use a Camera, and if the screen itself doesn't present hurdles such as undue hot spotting, gross retro-reflectivity, producing obvious color pushes, or is too dull / dim, that very accurate, exacting images can be had. Without effective post processing...a hideous taboo on this Forum...abysmal screen performance cannot be shown as being suddenly acceptable by any stretch. One can make things look "better". But near perfection does not come from a Camera suddenly turning a Pigs Ear into a Silk Purse. It just cannot be done, and those who insist it can...? Well I can't remember anyone actually going so far as to show that as being possible. If a shot has exacting colors, no crushing of detail...or whites...or Blacks...and shows fine shadows and no hot spotting, then it's almost assuredly a excellent image reproduction of an excellent source.
I'm going "there" because the shots I hurriedly took while getting ready to depart were nothing staged or optimized. They look very good for their being "Point & Shoot" in the real sense. That only happens when the Camera doesn't "have to" work hard. Everything within the captured frame is balanced.
Could you post the PJ settings and maybe some comparison pictures. Some that are straight on would be helpful.
Monumentally will have to take up that request as I'm almost 4 hours away. In as much as he's working feverishly to complete what is obviously a very raw, still being framed Theater, I cannot say at present when that will occur. I do know that after a weekend of movies spent lounging on Boxes and lawn chairs, the Screen was taken down and moved to a protected location and covered in Cloth.
The angle you took these pictures at kinda trips me out.
Straight on is easy...everyone does that...but if I did them like that, the very width of the screen would prevent me from capturing the entire surface AND showing the degree of reflected light present in the room. I'd like to point out that a 0.8 - 0.9 gain screen just doesn't reflect light very well...it absorbs light. So what does the shots showing Stud faces lighting up tell one?
Did you ever try the silver over white and take some pictures, especially with dark scenes...?
Wish I could'a, but as I said, I barely had time to pop in a DVD and get the ones I did. Maybe when I get back up there to go huntin' some long horned Wood Rats.
When I get my milliskin sample I'll be comparing it to a number of materials, but not sure I should post any pictures. I'm really wondering if milliskin isn't the same product I've been using from Fabric Land in Canada. It's also 20% spandex and very smooth surface.
It sounds close enough that absolutely you should. Even if there are slight differences, the differences you observe between Mole and Milli would be valuable input. Yeah, without it being exactly the same material, someone can (...and probably will....) state that the results are not indicative of acceptable results or precise enough to warrant suggesting such material to a DIY'er. That's bunk to the Nth Degree. The real concern is as to if the example is in fact done in the same manner. If so, I'll have no doubts about how it was done, and or why. You want to know...and others would like to see comments coming from someone with actual experience using a similar material in a real world test.
