First of all, a big Hello to everyone since I am new to posting at AVS. Also, a big THANKS for all the information that I have gathered since jumping into the home theater scene recently.
I have a very small budget set aside for this home theater since the wifey is not giving it much of a "nod" since it doesn't come in her particular color or fabric...LOL. I would like to have a 7.1 sound setup and there is enough room to build a 200" screen with just enough viewing distance.
I have enough funds to get a mid-range projector under $1000 (just bought the BenQ W1070), a receiver around $500, Blu-ray player under $200, and an amplifier if needed under $200. I have no choice but to recycle some old college speakers for the time being and that is where my problem lies.
I have some old "party" Wharfedale tower speakers: one pair of Valdus 400 and two pairs of the MFM-7's. I do know that the Valdus are 8 ohm / 150 watts and the MFM-7's are 6 ohm / 150 watts. I was going to use the MFM-7's as the front pair and the side pair. I figured the Valdus pair would be a good rear pair. I also have a Wharfedale Diamond center and a self powered 15" sub-woofer.
So how does one go about running two different ohm settings without buying a separate amplifier? Is that possible on any receiver? Or should I just run the entire setup at 6 ohm? Also, what type of receiver is going to feed a true 150 watts at 6 ohms without breaking the bank?
Any suggestions would be awesome; I just don't have enough knowledge for this stuff yet!
