Below is how I am tentatively intending to wire my new house. My issue is that I believe with this setup, I will only get 2 channel audio to everything.. even if I have only the living room TV watching a certain source (thanks to reading posts from people on here).
So my questions are
1) is there a work around for that, since I only have 1 TV i need 5.1 to.
2) Anybody have experience with a second switch after the Matrix? am I asking for trouble?
3) I know I could go component switching, but man.. that seems painful. And I assume since its analog I cant send it over CAT6.
Based on what I have read, I am probably in bad shape.. and either need to do it like the above and have a worthless home theater sound setup and wait for a new matrix' come out that handle this better
I could just by get rid of the matrix, and put every tv on a box. and then just manually run to the AV closet and hot swap the HTPC into whatever TV i want to watch it on. Then still split signal to the 2 TVs as needed in the diagram.
av diagram.png 91k .png file
So my questions are
