I have an onkyo 705 receiver and it's hooked to a paradigm cc-350 center, paradigm mini monitors for fronts, and a pair of paradigm titans for the surrounds. The speakers are 8 ohm but on the receiver I can only set it to 4 ohm or 6 ohm.
Another thing is the mini monitors say 80 watt max and the titans say 60 watt max and I believe the receiver is 100 watts per channel. I know you can have pretty much any speaker and receiver together no matter the watts if you don't crank the volume but I listen to my music rather loud and I worry about blowing my speakers or clipping my amp. Also when I switch from 2ch stereo to all ch stereo my sub output doubles, I've checked the settings and nothing has changed.
I know it's allot of questions but I appreciate all the help.
