I just bought a 200w Pioneer sub last night. I was happy to finally finish my 7.1 system after all these years. Everything seemed to be well. After making some adjustments, I was able to get everything setup and optimized to my liking (still need to make some tweeks).
Topic:
When I turn the receiver off (standby) it seems to continually send a low-frequency sound to the sub which, in turn, prevents the sub from initiating its own (auto) standby mode. As it stands, the sub's location makes it easy to reach the standby switch but the low-frequency sound is off-center. The ideal location (once I purchase a long enough cord) will be tucked away and the switch will not be easy to reach, therefore making the auto-standby option for the sub required.
I've read the manual (pdf), but being at work I can't test the settings. So far what I will try after work are:
Question:
Are there any other preempt suggestions I could try if the list above fails?
Topic:
- Setting the speaker sizes to small
- I kind of doubt this would have any effect on the issue, but it's in my tweaking itinerary.
- Turning off LPF
- The sub has a crossover frequency LPF. I was scrolling through the options this morning to try out different settings. I'm not sure if I tried this adjustment, but I know it was last left set to "on".
Question:
