Namlemez,
| ...read over it and it seems a little interesting but misleading |
Not really. Suffice to say, i disagree with most of your comments.
| Blowing things up brings out problems the eye can not see when viewed at any reasonable screen distance. |
Define reasonable distance. I am able to see a pixel structure (aliasing) at WXGA and above easily from a 'reasonable' seating distance, which is around 1.5 times screen distance.
| He also cheats and uses gaussian blur in there a few times. |
Cheat? Are you sure you understand why i used it?
| ... you simply have the scaler do what your eye does at normal TV differences. |
No, its not. This is a common misconception. And you probably mean 'TV distances'?
| This is noticeable when the image is 16x normal size on a high-resolution monitor when you are sitting 4" from it, but they essentially look the same if you view normally. |
Oh, maybe they look the same to you. If i show these images on my monitor and simulate a normal seating distance of 1.5 screen width by going the proper distance away from the monitor, i still see the difference quite easily.
| I see them talking about sampling, but in a general sense. All the additional stuff about scaling being the same as an oversampling CD player crashes down when you have to go back to a fixed digital grid. |
Not really. As someone else correctly noted, getting rid of the aliasing is simply more important than scaling errors to odd output resolutions.
| He himself has a CRT you can see on his webpage. Also, someone at the end of the thread basically asks if this is important to digital pj and is responded to with a "no." |
You misunderstood me there. The post had just as much to do with digital pj as with CRTs. The point of the pictures was that a DILA with ISCO can reproduce a 480p source better than a XGA unit, which in turn is better than a native resolution unit.
The 'no' you quoted simply implied that if you have a digital pj, you can't really 'choose' the highest and thus best possible resolution. You can't say, 'hey the higher the better, so i drive my XGA projector with UXGA resolution'. You should use the resolution of your panels instead. [There are seldom cases where using a higher output resolution than the panel's native res, has its advantages, though. The reason for that is a bit more tricky.]
| For the type of scaling that is done by PC video cards, the main thing eliminated is the pixel structure. If you can't see this to begin with (ie screendoor doesn't bother me)... |
Oh, absolutely. But if you can't see a pixel structure (with a properly focused lens) with a WVGA projector, you are either sitting way too far away to even call it a home-'theater' application, or you simply don't see that well.
If you 'see' it, but it doesn't 'bother' you, thats ok. But that doesn't change the fact that a higher resolution picture with less visible pixel structure wouldn't look quite a bit better.
| ...then scaling it up slightly to a resolution that doesn't work well with bicubic resizing won't be much of an improvement. |
Its true that there are 'sweet spots' when you scale. Probably the best known is 1440x960 (doubling X and Y), which can currently only be achieved on CRTs. Basically, problematic are resolutions that are 'too close' to the source resolution. Scaling 480 lines to 576 (XGA 1024x576) has more noticable errors than scaling to 768 (WXGA 1366x768).
But:
a) again, these scaling errors are less important than getting rid of aliasing
b) the horizontal resolution of WVGA units, 848 pixels, is SO close to DVD's 720 pixels, that it will have just as severe scaling errors in this dimension alone, as XGA units have combined in both dimensions.
c) these scaling errors mostly show up on the very highest frequencies that are contained on DVD ( in the 6.0 - 6.75Mhz band ). On most of the current DVD transfers, the frequency response is already severly down in this range. It will easier to see this on test patterns on AVIA.
| I know I'm mixing screendoor, viewable pixels and fill factor but I tend to think that my noticing them goes hand in hand. |
Agreed.
Regards
Bjoern
