AVS › AVS Forum › Display Devices › CRT Projectors › Trying to hook up my Sony rvc-6010q
post #1 of 3
Does anyone know how i can hook my Sony rvc-6010q to Run as a cable tv? I can get volume but no picture? I have no manual and very confused as to what the different plugs are for...wondering if i need an adapter or something? Any help would be appreciated.
post #2 of 3
Sure, read this:
http://curtpalme.com/CRTPrimer_17.shtm
You have a monitor with that unit, it has no built in tuner and you can't connect cablevision to it directly. Use a cable box or VHS machine to use as the tuner, then connect the video out to the Sony. That will give you a picture, but a terrible one. If the RP unit works well, then consider getting an HD box and a BluRay along with an HDFUry or moome box that will convert HDMI to RGBHV. That will look amazing, far better than a composite video signal.
post #3 of 3
  Back to Forum: CRT Projectors
