Originally Posted by raaj
What settings you've made using REW or a plain old sound meter prior to running Audyssey get overwritten after the calibration, so what's the point of analyzing the room prior to running Audyssey? The notable exception is adjusting the sub volume as I mentioned in my previous post.
Audyssey EQ's the results of prior efforts and then recommends changes to the AVR, based on it's measurement of the room's acoustics.
One is trying, via the old fashion method (manual), to get the best "MEASURED" response possible. One "MUST" use a room analyzing program as you can't do this with just your brain and a sound meter. No way, no how, it's not going happen. This is much more then simply calibrating both subs to 75dB at the main listening position. If one is not using a room analyzing program to augment their integration efforts, then nothing I'm posting will make any sense.
Audyssey EQ's the whole spectrum, not just the subwoofer end of the spectrum. One needs to have their subwoofer system fully integrated, prior to running Audyssey. The subwoofer spectrum is but a small piece of what Audyssey does when it EQ the interaction between the reproduced sound and the room's acoustics.
