Hi,I have moved my speakers about, so i need to re-run audyssey fully. The one thing that confueses me is the sub trim. Before i moved things around, the sub trim was set at -3.5 which seemed very boomy with dts master even with the voluume turned down to -12 using the ch level setting, but was fine with music being increased to about +8. Would it be better to increase the volume on the sub to try & get the trim into a + rather than a - value so there is more of a margin down to -12, or would it be best to stay with a - trim,
Thanks for any help offered Mark.
