I'm new to these forums, please forgive me if I posted in the wrong place, I really need help though.
I want to possibly build a small 2-way stereo system for my room, these are the components I have settled on. I am still learning how to select components for speaker projects, I've only done one other project before. I'll probably be making a cabinet for the speakers, something small as size is a concern. I need to know if these are compatible components. If not, please explain why not and what I should switch out. I don't have a huge budget, so I'm trying to save anywhere I can. The purpose of this project is just for something that sounds pretty good (maybe in comparison to a Bose Soundock, not as good as it gets, but satisfactory), but doesn't break the bank.
Here's what I have found:
http://www.amazon.com/Dayton-Audio-XO2W-3K-2-Way-Crossover/dp/B0002ZPL5W
http://www.amazon.com/Goldwood-GT-510-Soft-Dome-Tweeter/dp/B004GZ11RQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361051934&sr=1-1&keywords=Goldwood+GT-510
http://www.amazon.com/Dayton-Audio-Digital-Amplifier-Module/dp/B002IA9MYK/ref=sr_1_1?ie=UTF8&qid=1361051991&sr=8-1&keywords=Dayton+Audio+DTA-2
http://www.amazon.com/Aura-NS6-255-8A-Neodymium-Magnet-Woofer/dp/B004GBAJ4Q/ref=sr_1_1?s=electronics&ie=UTF8&qid=1361052077&sr=1-1&keywords=Aura+NS6-255-8A
http://www.amazon.com/2000mA-Switching-Power-Supply-2-5mm/dp/B001TY30EO/ref=sr_1_2?ie=UTF8&qid=1361052867&sr=8-2&keywords=12+VDC+2000mA+2A
If you have any knowledge of something cheaper that may work better, or work at all, please list it below. I'd be very grateful.
