AVS › AVS Forum › A/V Control & Automation › Remote Control Area › JobSite IR transmitter wire setup
post #1 of 4
I have searched extensively in vain for the correct wiring for my JobSite IR-CB1 IR transmitter system.
The connecting block IR receiver input slots are labeled ST IR G and V+.
The 4 wires are White Yellow Red and Black.
Does anyone know which wire goes in which input? (ie ST = White...)
Any help is greatly appreciated!
post #2 of 4
I decode those four signals as:
ST = STatus (the "talk back LED")
IR = IR signal received (the important one!)
G = Ground
V+ = +Volts aka Power
post #3 of 4
Thanks. Unfortunately I don't which color of wire goes with the STatus, Ground, etc.
post #4 of 4
Not giving us lot to go on here... What's that wire go to or attached to? An IR receiver? If so, what brand/model? If so, you should be able to find the color key from the manual...
  Back to Forum: Remote Control Area
