AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sony KDL-55W900A Owners Thread
Official Sony KDL-55W900A Owners Thread - Page 44
post #1291 of 4300
Originally Posted by pg_ice View Post
second misstake was to enable Adv.Contrast Enhancer
when you enable ACE it cuts the whites in the midtones and makes them brighter but you loose dynamic range in the picture.
Well, you are using Scene mode "General>Standard", not "Cinema". That makes a difference!
From my experience, the filters used in "Black Corrector" and "Adv. Contrast Enhancer" are always active in scene mode General. I found that when I try to "match" the picture between Standard/Custom and Cinema, and having both BlackCorr and AdvCE off in Standard/Custom, then I need to set both options to MEDIUM in Cinema to get a rough match between the scene modes. This means, the other way round, one of the main differences to mode "Cinema" is that you always have BlackCorrector and AdvCE filtering in Standard/Expert. It cannot really be switched off in those modes.
Compare the graph in the middle of this post. (External link, german "hifi-forum")
post #1292 of 4300
the cimena mode with the same settings as general/standard looks worse
dont you see it for your self?
as for the adv.Contrast Enhancer
IF it had been active all the time in scene mode General i would have seen it when i measured the gamma cuve with my colormeter.
it isnt active because the gamma curve is flat.
ACE screws up the gamma curve and you will see it directly if its on or off.
i have not measured the cinema mode and the standard mode with the same settings but i can do it.
i post the results later
post #1293 of 4300
Rarely will two different picture profiles require the same settings to produce optimal results.
Try to run a completely new calibration in Cinema and see what kind of results you can achieve. To my eyes, a Cinema profile that I had merely tweaked blew Standard away. Then again, accuracy and personal preference may diverge for some, so you're free to enjoy your television any way you'd like.
post #1294 of 4300
ok more measurements
you get different light outputs with different "Motionflow" settings.
here they are
(no other setting changed but motionflow)
Clear: 191 cd/m2
Standard: 228cd/m2
Smooth: 228cd/m2
Off: 228cd/m2
True Cinema: 228cd/m2
Imulse: 72cd/m2
Clear Plus: 142cd/m2
post #1295 of 4300
- In which way worse? If you mean s-th like "less punchy", then ... yes, that could very well be. Standard/Custom does have "more punch". And now, guess why that is? (Start with thinking about for what technical reasons that possibly can be.) wink.gif
I'm not sure in how far a gamma curve screwed by adaptive filtering can be seen in standard measuring. Means, this will depend on how the pictures for measuring are designed. What I would do if I had measuring equippment (I don't have) is: measure i.e. an IRE20 patch that is surrounded by IRE0 or IRE10, and measure an IRE20 patch that is surrounded by IRE80 or IRE100, and measure a screen that is all flat IRE20. My bet is that those readings of IRE20 will be noticeably different, when using picture mode standard or custom.
A common-sense approch without measuring equippment:
- All settings equal, (and BC + ACE both "off"), the picture modes "standard" and "cinema" look quite different
- keeping BC+ACE off for Standard, but setting them to low or medium for Cinema, "Cinema" becomes looking much more similar to "Standard".
The conclusion of this behaviour is quite obvious.
post #1296 of 4300
i have done measurements with the same settings in both GENERAL/STANDARD and CINEMA modes
the only thing that the Cinema mode changes is the gamma curve
and it changes it to the worse
i have checked 2 times and got the same result on both
minor changes in the color saturation between the both modes
the cinema mode lowers the gamma curve in the high tones around IRE90
Use STANDARD mode to get the best gamma curve from this tv
The last test was with Adv:Contrast Enhancer set to MEDIUM (the other settings was the same on both modes)
ACE beaves different so i suggest if you must use it
use it with the CINEMA MODE.
Edited by pg_ice - 9/14/13 at 9:52am
post #1297 of 4300
yes they do
just as i have measured you get more washed out whites with cinema mode.
other than that you seems to get a tad more saturation in Standard mode
you can see it in the Luminance chart for the Blue and Magenta color.
im switching between them just now with the movie Oblivion
look at the clouds at 2:13min
Edited by pg_ice - 9/14/13 at 9:49am
post #1298 of 4300
Hi All,
I just purchased the W900A directly from Sony, and on noticed the backlight is uneven along the edges. I tried to capture the problem in photos, but it's a bit hard to see... You may have to squint a bit biggrin.gif. Anyhow, i haven't seen anyone else posting about this problem. Am I the only one? Do I exchange the the TV? Thanks!
post #1299 of 4300
Originally Posted by gnl63 View Post
Hi All,
yes i can see them
thats not right
return your tv!
post #1300 of 4300
How do you see that backlight screen?
post #1301 of 4300
The first two images are AVS "inspired" test patterns from YouTube. I don't know how authentic they are, specially when compressed via uploading to YouTube, I just needed any video with a full clean white background.
post #1302 of 4300
lol
get the real ones here
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
i use the MP4 patterns
post #1303 of 4300
lol
Haha thanks for the real ones! Have you ever seen this uneven backlight behavior on your TV?
post #1304 of 4300
im will check soon
just checked
nothing here
Edited by pg_ice - 9/14/13 at 12:17pm
post #1305 of 4300
Incorrect -- as you can measurably verify. Again, calibrating one picture profile and then carrying over those settings to another profile does not produce the optimum picture for the latter and subjective tastes may not correlate with standardized accuracy.
post #1306 of 4300
I just got this TV not long ago and was wondering what is the best calibrating settings there is for a movie, sports, and tv shows? I'm trying to do some research on my end as well, but I'm coming up short.
Edited by Driice - 9/14/13 at 12:17pm
post #1307 of 4300
it gives a great contrast
this backlight system works so well so you can crank it up sky high without getting Blooming/Clouding/Halos you name it smile.gif
just a razor sharp bright image
thats with backlight at 6
max peak light is 301cd/m2
slight lower with the "Clear" motionflow setting
Edited by pg_ice - 9/14/13 at 12:29pm
post #1308 of 4300
my settings is the best
10 days of adjustments and calibrations there.
top of the thread
post #1309 of 4300
Hi All,
The w900a does have darker edges, but that is extreme. It should be hardly noticeable unless you are really looking for it, and it should only be possible to see on bright images.
Edited by *UFO* - 9/14/13 at 1:15pm
post #1310 of 4300
backlight at 8
that should be around 250cd/m2 peak brightness
unless your monitor is at 250cd/m2 its hard to see the brightness
its bright.
those fireworks lighten up the room completely
Edited by pg_ice - 9/14/13 at 2:12pm
post #1311 of 4300
top of the thread
I've tried your set up and at time's it is good, but sometimes the picture is still blurry.
post #1312 of 4300
for material with low noise you can turn OFF these
NOISE REDUCTION: MEDIUM
MPEG NOISE REDUCTION: MEDIUM
that makes the image sharper
Edit: i have change my settings above
after some more testing i find that those two noise reductions is overkill and not needed.
they only blurs out the picture.
Edited by pg_ice - 9/14/13 at 6:46pm
post #1313 of 4300
Do the graphics suck on madden 25 and ncaa footall 14 or am I just used to playing my 360 on a smaller tv. Also in diablo 3 the characters look a bit low res, probably didn't notice it as much on a smaller tv.
post #1314 of 4300
I just bought a sound bar and was wondering if there are any other options I can tweak to make the image better since I now have sound playing elsewhere?
post #1315 of 4300
sorry i dont understand what you mean.
what has sound to do with picture settings?
if your picture isnt good with my settings it must be the source material or something else that is bad.
i need to praise the "Blue" backlight with its Quantum Dots on this tv even more! smile.gif
im now using 8 in backlight and that is crazy high for a room with only 4cd/m2 ambient light( 3 40watts Lamps)
normal LCDs cant handle this high light output but this tv has no problems with that.
it ONLY adds even more contrast and brightness to the picture.
no sideeffects!
test my settings with backlight of 8 instead of 6 and start the movie Oblivion.
then you must agree that the picture you are seeing has the highest contrast ratio you have ever seen.
just like you are there.
230cd/m2 peak brightness in a dark lit room
Edited by pg_ice - 9/14/13 at 7:56pm
post #1316 of 4300
Originally Posted by grif82 View Post
Man, oh man....and I was just about to pull the trigger on the 55" W900 knowing that I'd rather a 65" model. Great news indeed for those that have not purchased one of the W series 55" models. Only thing I see different off the Sony website is the the new 65" W850 uses Motionflow 480 vs 960. Although, it still retains the Triluminos display of the W900. Hopefully the input lag time remains the same for gaming use.
Why is this? Makes no sense. Is the W850 still a 240hz panel?
post #1317 of 4300
Originally Posted by malcolmp6 View Post
It looks like the 65w850 is matte and not glossy like the w900a. I wish i had waited 2 months before i purchased the w900a.
Why do you say its matte? The 900a is reflective like a mirror in the day, but that also contributes to the contrast. But you need some dark curtains during daytime. At this point the W850 is a big unknown. I am returning my W900a. Sony gives you 30 days to return it after you get the RMA. I waited until the 29th day to get the RMA, knowing about the W850. I'm certainly waiting to get feedback on it before buying it.
post #1318 of 4300
The motion flow 960 vs 480 is a gimmick. I feel that Sony made the w850a motion flow 480 to keep it "technically" under the w900a to keep the current w900a owners happy. In other words, if they had made an exact 65" version of the current w900a common folk would be angry knowing its in the same price range. It may even be possible to flash the w850a with w900a firmware and have yourself a 65" w900a.
post #1319 of 4300
Also, the screen is glossy on the w850 not matte.
post #1320 of 4300
I've found the following to be a great baseline setting: http://www.hometheater.com/content/sony-kdl-55w900a-3d-lcd-hdtv-settings
I bumped the Sharpness up to 50, and tweaked the Backlight, Motionflow, and ACE to taste. Most pro review sites leave all Noise Reduction option off.
