Our new home construction build is to the point where electrical, plumbing, HVAC and low voltage wiring is being installed. I have always been a "whole house audio with in-ceiling speakers" kind of a guy but lately I can't stop thinking that Sonos is a better option for background/informal music.
A little background: 5 bedroom house with finished basement. Basement is going to have a theater room so I won't need anything down there as far as separate audio goes. Upstairs I want to have audio in the hearth room and kitchen (basically 1 room) and 2-story great room and maybe the master bedroom. I also want the ability to have audio in a screened porch (when we are using it) and the bonus room (again, when we are using it). I am not going to spend hundreds of dollars on each speaker and will likely buy Monoprice 6.5" or 8" speakers if I go that route. I will have Cat6 in each room.
So we are talking about 2-3 definite zones with 2-3 optional zones.
Personally I think the wall keypad/controls are going to be extremely outdated in a few years (that is to say I really don't like them). With everything going the way of ipads, Nexus 7, etc there is just little reason to use this as part of the system, imo.
So if I went with three Play:5 in each of my definite zones ($400 x 3 = $1200) plus a Sonos Connect for $350 (so I can connect a HTPC to the unit). So that is a total of $1550. Then maybe 1 additional Play:3 or Play:5 as a "mobile" player that I could use in the screened porch, bonus room, garage, or wherever else I want to use it.
A mid-range HTD system with 4 pairs of Monoprice speakers is roughly $1700 plus a Sonos Connect ($350) which is around $2000. So figure that the cost is roughly equal.
I have also heard that the Play:5 sounds better than most inexpensive in-wall or in-ceiling speakers.
So where am I wrong or what haven't I thought about???
If something comes along better than the Sonos setup, you want your house wired for all the options.
