AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Can you stream from VLC to PS3?
post #1 of 2
Hi,
Is it possible to stream video from VLC Media Player to the PS3? MY version of Windows 7 Did not come with Windows Media Player (I have Windows 7 Ultimate N) so I use VLC media player (which is much better, by the way) but I cannot figure out if I can stream video from the VLC to the PS3. Does anyone have any experience with this?
thanks.
post #2 of 2
You can, but you have to set it up on your pc every time you want to stream, by opening it in vlc and telling it to stream.
A much better solution is to use this link to set up windows as a dlna server, or install serviio (which is probably more simple). Then point your ps3 to the dlna media server on your pc. This way you can point the server to a folder with your files that will always be available for streaming. Much better solution.
Or ps3MediaServer is another solution made for the ps3
Edited by ZmHD69PigQ - 2/18/13 at 6:17am
