Hi all.... Thank you anticipatorily for any comments or suggestions. Here's my initial plan, including goals for the HTPC and NAS services.
As for building skill, I've successfully built one gaming computer from scratch but that was 6 years ago. I know the world has changed since then.
Combination HTPC and NAS
HTPC goals:
Store and display family photos
Store and display about 20 hours HD and 60 hours SD home movies
May or may not want to store and display some or all of commercial BluRay and DVD collection
Store and play music collections by individual family member (if possible)
Integrate our other video services (if possible): Netflix, Verizon FIOS TV (have multi-room DVR)
Wife can control the HTPC from the couch or the kitchen with her iPad
I can control the HTPC from the couch with my (soon to be purchased) Surface Pro 128
Kids can control the HTPC from the couch with their iPhones
NAS goals:
Store and access family photos, music, and videos (above)
Store and access family documents
Sync and backup >100 GB work files over LAN (or auto-sync over cloud if I can figure that out) ... work is about to move to MS 365 cloud-based system
Automatic file backups (RAID 5?)
Initial draft hardware list:
GIGABYTE GA-Z77X-UD4H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128583
$164.99
Intel Core i3-3225 Ivy Bridge 3.3GHz LGA 1155 55W Dual-Core Desktop Processor Intel HD Graphics 4000 BX80637I33225
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116774
$144.99
Stock Intel i3 Cooler
SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147188
$109.99
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231427
$29.99
SILVERSTONE Black Aluminum / Steel Grandia Series SST-GD08B ATX Media Center / HTPC Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163196
$155.99
Western Digital WD Green WD20EZRX 2TB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236404
$89.99 x 4 = $359.96
SeaSonic X series SS-400FL Active PFC F3 400W ATX12V Fanless 80 PLUS Platinum Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151097
$119.99
Software:
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
$99.99
JRiver MC18
JRemote via iPad, iPhones
(JRiver remote solution for Surface Pro pending)
MS SyncToy for sync / backup (unless a RAID solution is better and I can figure out how to set it up)
Thanks again!
HTPC goals:
NAS goals:
$164.99
$144.99
$109.99
$29.99
$155.99
$119.99
Software:
$99.99
JRiver MC18
Thanks again!
