Hi, looking for a sanity check and suggestions here...
Looking for a compact sub Minivee 8 footprint is ideal, could stretch to the SVS SB-1000 footprint but that would be the max. Usage would be 60% music (all types) and 40% HT. Sub will be in a corner behind a 46" display in a ~2800 sq/ft room with many windows. Was all set on the Minivee 8 but the SB-1000 creeped in.
Overlooking price (for now), what are thoughts on all-around performance between these or is there another option (smaller footprint than SB-1000) that I am missing?
Thank you!
Thank you!
But, for what little it's worth, here's what I think: The SB-1000 digs deeper, and it likely plays flatter overall, which means that while it may not be as "punchy" as the Minivee 8, it should be more "accurate".
