AVS › AVS Forum › A/V Control & Automation › Remote Control Area › GC100 RS232 Port Expander?
post #1 of 2
Is there a market for an RS232 port expander to be used with the Global Cache GC100? Such a device would in no way modify or compromise the GC100. It would just add 8, 16, 32 RS232 ports as needed?
This could also be used on other controllers with two serial ports.
Is there a market for such a device?
post #2 of 2
If you need more than a few serial ports, a "serial console" / "terminal server" with Telnet will be a better solution. They're readily available...
  Back to Forum: Remote Control Area
