AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Need help for small Church sanctuary
post #1 of 2
We are trying to upgrade our small church media to take down our current projector and add two on each side of the stage. They will be hung from 15 ft away from the 96 inch 4:3 screen. Does the ViewSonic PJD5233 look like our best option under 500 (preferably 450)? Thanks in advance
post #2 of 2
According to the calculator at Projector Central this projector has to be within 13 feet 10 inches in order to fit a 96" (4:3) screen.
http://www.projectorcentral.com/ViewSonic-PJD5233-projection-calculator-pro.htm
What projector are you replacing? Most of the people who post in this forum have limited or no experience with business type projectors.
Given your budget restriction call the good folks at Projector People and state your goals to see what they recommend.
http://www.projectorpeople.com/projectors/projectors-under-500.asp
