AVS › AVS Forum › Audio › Speakers › I need cheap towers. Used ok.
post #1 of 13
Hey guys I am looking for a pair of floor standing speakers. They will be used for music only. And as far as music type, I listen to everything besides country music.
Size doesn't really matter. My budget it 1000 max. Audiogon any other used sites are okay. I live in PA and there are not a lot of high end dealers in the area for me to find a set used or anything. What do you guys recommend?
post #2 of 13
fwiw, take a look at the focal 814v's $800 at accessories4less
post #3 of 13
Is that seller reputable I never used that site? I have been looking at the focal 714 used for 699 or the 716 for 899 used so this would be a good price.
post #4 of 13
+1. I don't think there could be a better set of speakers at that price point!
post #5 of 13
what is normal retail on those? 1800?
post #6 of 13
fwiw the focal 814v is the focal 716 in gloss black. accessories 4less is an authorized focal dealer and very reputable i have and many other avs members have bought from them. they retailed for $1800. music direct sells the 716 for $1500
post #7 of 13
Define "Cheap" ...what are your criteria.. No sub so you want a good amount of bass?
post #8 of 13
I did define "Cheap" 1k to spend.
And I do have a sub if needed, but it will not always be used.
post #9 of 13
So 1,000 to spend only on the front two speakers right? Don't need speaker wire, reciever, speaker stands, players etc...we are talking 1k for front two speakers? Just clarifying because there are allot in the 1k budget range but your choices become more limited at the 800 range...and severely limited in the 600 range.
post #10 of 13
Yes only the speakers. The 1k is speakers strictly. Anything else that I do not have will be purchased separately. I have been doing research on the focals originally suggested and I am leaning towards them. I was considering the Swan Diva 6.2 speakers but now I am more into the focal.
post #11 of 13
...wrong thread.....
post #12 of 13
Anyone else have an opinion?
post #13 of 13
LSI15 refurbs on Polks ebay store. $849 for the pair.
http://www.ebay.com/itm/PAIR-LSi15-LSi-15-CHERRY-Tower-Loudspeaker-Polk-Audio-/230629800429?pt=Speakers_Subwoofers&hash=item35b29b79ed
  Back to Forum: Speakers
