Building my first thater in the home I purchased. The entire basement is finished and I found a room that is, what i thought, the perfect thater room. After further review I am really worred because I dont know what projector I can purchase and thinking I might have to have one with lense shift. Originally I thought about mounting the projector at the far back of the room which is about 18 feet from the screen and figured I would just drop it down a foot from the ceiling but then I am reading I would have to use major keystone adjustment which is a no-no. After playing with the elite projector calculator it appears this room is going to be terrible due to the height constraints. As you can see below, the entire room is 6'7" and there really isnt much I can do to gain significant height. I only want to go with around a 100-120" screen and was looking into the entry level 1080p PRO 8200vbut now I dont think this will work. I am starting to consider the BenQ 710 short throw and mount it to the front soffit about 6 feet away and fire it right at the wall but dont know if that would look silly or suffer quality. Can anyone please help me? I am budgeting under $1k and wanted to do 1080p 2D. I dont want to buy the wrong unit but I am dying to buy my first projector soon!
Here is the view from the current couch
Here is looking back at the seating area
Here is the closeup of the ductwork
Edited by tshepp - 2/18/13 at 4:44pm
