AVS › AVS Forum › Audio › Speakers › Looking for Bookshelves under 1000 or other options
post #1 of 9
Really wanna keep the speakers to under 1000 pair..maybe 1500 tops. Looking at the Golden Ear bookshelves or Martin Logan bookshelves..they are around 800 pair and both have motion tweeter. Honestly,not impressed with the the Def Tech and JBL and Focal lesser offerings compared to Golden Ear. I am looking for suggestions on brilliant sound within the above price budget. Thanks
post #2 of 9
Ascend Acoustics Sierra-1. And if you want to spend more of your budget, you can do the optional tweeter upgrade.
post #3 of 9
Some other options...
Monitor Audio Silver-RX2 ($1000)
PSB Imagine B ($1100)
NHT Classic Model Three ($900)
post #4 of 9
+1 w/ the upgrade
post #5 of 9
anybody else please
post #6 of 9
If you don't mind buying used, you will open up your options quite a bit. Dynaudio, Totem...Salk, Fritz, Swan, Dana, GR Research are just a few that I would through into your sights. For example, Swan D2.1se's, I thought were just a wonderful speaker, can be bought outright AND can be built with high dollar wire and crossover and still come in under a grand. ..As mentioned above, Ascend ANYTHING is a fine choice....The Sierras are very hard to beat. My system seems to be a constant search and evolutionary project!LOL In the last 5 years I have had 6 different set ups in my main room, 3 Dyns, 2 Ascends, a Swan and I am now back to Dyns... Right now, I am content with a pair of used Dyns I found for an awesome price for a "like new" pair....How big is your room? Will you be using a sub? What are your listening habits? What kind of music do you like to listen to? All these are questions that will help others help YOU...ONLY YOU should decide where you spend your money, but there are lots of choices for sure. Have you spent any time on other forums? Audiocircle and audioasylum come to mind, as well as DIYaudio....LOTS OF GREAT INFO to read through
post #7 of 9
post #8 of 9
Give Dennis Murphy a look. Awesome speakers for the money. Ribbon tweeter... Don't think you will find better for that price range honestly.
post #9 of 9
Ascend Sierra-1s with the NrT tweeters are pretty hard to beat and are a steal that their price,
  Back to Forum: Speakers
