I am trying to make sure my settings are correct on my HTPC and I have a few questions regarding my settings.
I have an LG Plasma TV with the black level on the TV set to high. MyHTPC has a AMD 7970 outputting the Full RGB 4:4:4:4 Pixel Format.
I have disabled all AMD Video enhancements in the Catalyst Control Center except the Video Quality enhancements, I have left those on default settings.
All of the following are turned on.
Edge-enhancement
De-Noise
De-Blocking
Enable Dynamic Contrast
Enforce Smooth Video Playback
Should I leave these on or turn them off?
I should note, I use TotalMedia Theatre 5, XBMC 12.0 and VLC and Media Player Classic to play my media.
2nd question, I am using a custom .icm file that I downloaded for my gaming monitor to help with the colors. (out of the box is terriable)
When I hook my PC up to my HT and Plasma TV to watch blu-rays or mkv files, do I need to turn this .icm color profile off? If so what is the default color profile for Windows? I see one called sRGB Virtial Device Model Profile (wsRGB.cdmp)
Is this one adequate?
Sorry for all the questions.
Edge-enhancement
De-Noise
De-Blocking
