Can someone explain the screen mode Full Pixel vs. Normal for me?
From what I understand, when turning on Full Pixel, you are essentially seeing a full 1080p image. The downside is that you may see slightly more than is intended and could send vertical lines on the screen in the corner.
So with that said, as someone who wants the picture to be as the director or the source is intended, do I want Normal or Full Pixel? Full Pixel to me almost seems as it's zooming out per se and showing what wasn't intended. Is this not the case? Is Normal cutting off the picture and Full Pixel is correct?
