I have a pc connected to an onkyo txnr709. If the receiver is on when I power up the pc it gets recognized fine but if the pc is turned on first it handshakes with the tv due to the pass through on the receiver. This works as it should and allows me to use either the tv or receiver for sound but I need to reset the handshake when switching.
Pulling the hdmi cable out and replugging it works to reset it but it's annoying. Restarting the pc works but it's super annoying too. The best way so far that I've found is to change the resolution on the pc. Are there any better ways?
If there was a program that could do this, I could pin it to the taskbar and use Win+# to start it. Ideally it would just run when opened and then close that way you could program a remote for this function.
