Greetings,
I'm hoping someone out there might be on the same boat ........
Does anyone know if there's an AV receiver out there that can send the HDMI CEC signal to an Epson Home Cinema 3020 to power it on when the receiver is turned on?
I just got the Yamaha RX-V473, and though they both support HDMI Link .... and the Epson has settings to allow it to get "power on" ... it doesn't look like they are compatible with each other. The receiver doesn't show up under the "device connections" of the projector settings
Would I have better luck with a Denon or Pioneer AV receiver?
thanks a ton! :P
thanks a ton! :P
