Here, I took two. Couldn't get all of the numbers at once to show. Notice how the 'X' in the top cap seems to bulge out a little? It is actually bulged in reverse of what the 'score' is on the cap, though the top of the actual cap does not look that bulged. PS works fine. The power comes in from the PS through here first into the main board, but just disappears at this spot on the board...thinking it MUST be these three caps....I hope....but, I can't figure out what they are in order to purchase them online Would you also agree with my logic on this being the issue? There is NO power to the rest of the TV...no fans on, no lights on the front, can't access the error message light codes for the power light on the front...absolutely nothing works...New PS, reset switch works, relay on PS clicks when plugged in...though Power button on the front of the TV does not work (it's tied into the Main board I believe). ALL circuits funnel electricity from this one spot at the beginning of the main board where power comes into it....all Surface mounted fuses show continuity too. The only odd thing I could find anywhere else on the TV is a diode on the PS, between the board, and ground, that I cannot get a reading with my Fluke of any kind through. It's one of those glass bubble kind, with the black spring, or carbon looking thing in the middle. It looks a little misshapen, and appears to have sort of melted into the glass, but it isn't burnt at all, nor does it look blown...not sure what that is, and the local large electronics supplier basically refused to help me do anything towards replacing it, looking it up so that I could order another, or giving me any sort of opinion. What jerks...they lost my business forever... anyway, I'll move onto that being the cause after replacing these caps, maybe bypass it by making a jumper to see if anything turns on...but like I said, brand new PS from the factory...that shouldn't be the issue, and it doesn't make sense that it would be.
Thank you for your help.
