Originally Posted by beastinsince85
NOOB question. I have a small room maybe 8x15. No windows, underground, so no external source of light. With this projector in this room, will a screen make a noticeable difference, or can I project directly onto the wall. I've also heard that you can buy a special paint for the wall. Does anyone have experience with this?
I recently posted these comment in another thread:
No painted wall can match the performance of a projection screen that is perfectly smooth with optical coatings. It is a physical impossibly to duplicate the smoothness of a good screen with paint. It is hard to get a perfectly smooth surface with any paint system and to whatever extent there is texture on your screen surface there will be a corresponding loss of image detail. Any screen you buy should have a perfectly smooth surface with no texture. Most cheap screens have a textured screen surface which is inferior. The projector and screen are a system and the PQ is only as good as the weakest link. I would recommend the Vutec Eleganté fixed frame wall screen, with matte white surface if you are looking for a good cheap screen. I would stay away from gray screens. Gray screens used with current high contrast projectors are a solution to a problem that no longer exists. With a gray screen you sacrifice your whites, image detail and although the blacks will appear blacker if you carefully scrutinize the blacks of gray screen versus a white screen you will see the details in the blacks are crushed as well. Detail, fine graduations of half-tones, subtle shifts in color, intact gray-scale, pure whites and blacks with detail are what allows the viewer to perceive a flat image as having dimensionality. Because a painted wall cannot resolve this detail your image will not achieve its full potential.
Edited by leckian - 3/13/13 at 7:44pm
