AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung HL-P5060 has audio, lamps on, color wheel turning ,no error leds and it has no video
post #1 of 2
Samsung HL-P5060 has audio, lamps on, color wheel turning ,no error leds and it has no video. I have changed the digital board because the menu will not come up on screen. Still same results. Changed DMD board no change. Temporary swapped DVI cable no change. Is it any merit in changing DLP chip ? No video using DVI,HDMI,Coax or composite inputs. Source works on remote, can tell by audio based on dvd, cable box, wii. Any suggestions will be appreciated.
Baham
post #2 of 2
Model # correction Samsung HL-P5063. I recently sent the A/V out to another TV, was able to see analog inputs Coax Cable and Composite Wii console. HDMI nor Componet inputs would display on external TV. Audio on all inputs could hear on P5063. Menu would not display either. I have already purchased a digital board from ShopJimmy and installed it resulting in no change. This board was used now I am wonder if it was bad too because everything is lead to it. Have changed DMD board with no change in problem. I have been checking power supply voltages.
Help
  Back to Forum: Rear Projection Units
