AVS › AVS Forum › Audio › Speakers › Need Help Deciding On Surround System
post #1 of 7
So i can get any MartinLogan or Definitive Technology for a really good price and need to know which one will be better for my surround sound system.
I thought i was going to get the definitive technology 8060's for the fronts, and center, and 8040's for the rear. But then i noticed i can get martinlogan for a great price and now don't really know what i want to do.
Please let me know what your thoughts are and why i should do one over the other with specific reasons. This will be used for a 5.1 5.2 or 7.2 system.
Thanks for all your advice and help ahead of time.
post #2 of 7
I have heard both...I am assuming the ML's are the Motion series? If they are, then I preferred the Martin Logans. I thought they just sounded fuller....but that is just my opinion. I wasnt impressed with the Def Techs
post #3 of 7
Yes motion 40's or the esl
post #4 of 7
Anyone else???
post #5 of 7
We are missing a ton of information if you want advice... Size of room, budget, Home Theater to Music Use * 50 / 50 or 75 / 25 *
Do you have a reciever...what do you have...is a new one in your budget.
Subwoofer?
post #6 of 7
So the room is open concept 15x15 lets say 80 to 20 movies to music reviewer will be a Yamaha 2020 which will be $750 of my budget the speakers will be the rest if I did the 8060's I would run the subs in the speakers
post #7 of 7
Budget won't matter because of the cost I will get speakers at let's just say its a great deal but in my price would be Martin Logan motion 40's def tech mythos st or 8060's or martinlogan esl
  Back to Forum: Speakers
