I have a home theater with a BENQ W6000 (1080p projector). Its only 1 year old so I don't plan on upgrading anytime soon.
I currently have the following HTPC setup for the home theater:
AMD X3 720 BE (unlocked to X4)
4GB RAM
2x Sapphire AMD Radeon 4850s crossfired (I believe they are each 512 mb memory)
Windows 7
Corsair 650W PSU
One of the most annoying problems that I have is that I cannot leave the HTPC on. If the HTPC is already on when I turn on the projector I get "popping" noises (almost like fireworks). I am guessing that maybe it has something to do with the 4850 cards because that doesn't happen on any other A/V device that I have. And it happens with any A/V receiver. I used to have a Pioneer A/V receiver and I got the exact same popping sounds as soon as I would switch over to the HTPC. I always have to turn on the projector first and then the PC to avoid getting the popping noise.
4GB RAM
Windows 7
Corsair 650W PSU
