AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Help in Denver
Help in Denver
post #1 of 2
Hi all
New to forum and have little to no knowledge in this subject
so any pointers would help.
Want to go OTA with DVRS and streamers in the next couple months
So my first step is antenna called Antennadirect and a lady recommended the www_antennapoint_com_antennas_show_id_9009 west san juan drive littleton, co 80128.pdf 456k .pdf file
Clear Stream 2V so OK I bought it.
To cold to go outside yet OK maybe not too cold but soon.
So I put it in my upper level bedroom to see the results
I hooked it up to a 2009 Toshiba 42LCD so tuner should be OK
I received 5.1 7.1 7.2 9.1 9.2 12.1 12.2 and distant 78 { Spanish }
Please help what did I do wrong or is this my destiny ?
Thanks for your help
Jim
post #2 of 2
You need to go back into the TV's setup menu, take it off the CABLE setting (put it on ANTENNA), and re-run the channel scan. See TV set owner's manual, if necessary.
Your antenna choice should work fine.
