AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony 900 for XBMC- programed but need help on one button
post #1 of 2
I have programmed my harmony 900 remote and almost everything is working great to scroll through and play movies on XBMC.
One issue though...
I can't go back one level when scrolling through the different levels within the menus. I have programed the channel return button with BACK (did nothing)and with ESC (takes me all the way back to the main menu screen). What should I use to allow me to go back just one level within the menus?
post #2 of 2
Solved.
To go back one level within the menus program a button as BACKSPACE
  Back to Forum: Remote Control Area
