Hoping the 2.35 CIH crew can perhaps help me out with selecting a screen size. I'm ultimately looking to go Seymour AV AT-screen. 2.35:1 ratio, but would consider a curved screen if its needed.
The current unfinished dimensions of my theater build are 172" wide by 244" long. From left to right ,I figure to eliminate 10" for framing+drywall leaving 162" of space to be used for screen-width.
My initial plan was to create an AT space of about 30" deep... minus ~5" from the back wall for framing+drywall and thats 208" from back wall to screen wall.
How big of a 2.35 screen can I go along with the use of an A-lens (likely the Prismasonic). My initial thought was 120" wide... but can I get away with 130"? or 140"?
Is the throw distance (or throw ratio) measured from the front of the projector or with the A-lens in place?
