AVS › AVS Forum › A/V Control & Automation › Remote Control Area › URC RFS200 Any RF remote better for under $100? Questions as well.....
post #1 of 4
Just looking at various universal remotes as I need to consolidate my 8 remotes down to one and need RF for my components in the closet behind the HT. From what I can tell, this RFS200 with the RF20 remote and RF base station seems to be the best under $100 solution ($70 on Amazon) unless I missed something?
Also as far as the RF20 goes, I assume you can rename each of the 10 devices on the main LCD screen? So I could name the first Onkyo, the second blu ray, the third Lumagen, the forth Darbee, etc........?
One other question is can I set up 3 different Macros?
1. JVC projector, Onkyo receiver, Oppo blu ray player
2. BenQ projector, Onkyo, Oppo
3. BenQ, Onkyo, 360
Can this be done with the RF20
Edited by Toe - 2/20/13 at 9:08am
post #2 of 4
You can rename every input everywhere.
3. BenQ, Onkyo, 360
I believe the macro limit is 99 or something ridiculous. I'm using around 20 right now.
As long as you have dedicated on/off buttons the rf20 is great.
Go through the instruction manual carefully as there are a ridiculous number of features to use.
post #3 of 4
99 Macros? That is it? tongue.gif That is nuts.
Thanks for the info Macks. I have one on the way and looking forward to it!
post #4 of 4
Actually there is only 5 devices on the main page, to see the other 5 you have to page to second screen.
  Back to Forum: Remote Control Area
