Originally Posted by
A9X-308
Is that 6cf for one driver or two? It's too small for 2 ported but OK sealed. Sealed you will need EQ, and ported you will need a high pass filter.
Two enclosures at different locations in the room will even out LF response, and some creative thought applied to the enclosure could minimise/reduce some appearance issues. For example, make 2 end tables, drivers facing down and the enclosure spaced off the floor on short legs.
I plan on doing two enclosures.
gtpsuper24
I had though about purchasing some plans from him. But after I got to looking it seems like what he calls a rear loaded horn or some other kind of weird made up name "ducted" is just ported enclosures. I just will stick with BFM's designs, if you want horns that aren't just a ported box. $50 is alot of money for ported box designs.
Different woofers call for different enclosures. I mentioned PWK as he is able to compare a multitude of enclosures, not just sealed and ported. I have never heard a horn or tranmission line and I figure it's best to let someone who has experience make the determination of what might produce the sound I'm looking for based on the criteria I laid out, whether that be sealed, ported, bandpass, transmission line, horn, or passive radiator. Yes $50 is a lot of money to spend on a ported box design, or possibly sealed, but it's like an insurance policy to ensure that I get the best possible enclosure given certain size constraints.
