AVS › AVS Forum › Video Components › Home Theater Computers ›  Dual G-Skill DDR3-1600 F3 2Gb Ram and Asrock 75m-gl not playing nice....
post #1 of 3
I'm trying to upgrade my Win7 64 bit HTPC to 4gb of ram from 2gb. Windows will not boot if both stick are installed. The BIOS will recognize any combination of the ram. Windows will boot with either stick in either slot.
Intel g1610 chip.
Im lost???
post #2 of 3
"Upgrade": what do you mean by this? You have a stick of 2GB memory, then add another? If so, what's the model number of each?
post #3 of 3
I'm confused
Did you buy another mismatched ram ?
