AVS › AVS Forum › Audio › Receivers, Amps, and Processors › no sound/audio on Denon AVR1913
post #1 of 6
I'm new to receivers, I just got this last week, connected all my speakers and subwoofer, I tried it tonight on the fm selection but no sound is coming out to the speakers and sub. can somebody tell me what I am doing wrong ?
THank you
post #2 of 6
Have you connected the included FM antenna to the back of the AVR? If yes, try moving the antenna wire around to see if there is a better location for it.
Also note there is a dedicated thread for Denon AVR-XX13 Owners linked in my sig. Review posts #3-6 in that thread for additional helpful information.
post #3 of 6
JDS,
yes I did and even tried connecting my ipod and still no sound.
post #4 of 6
Ah, so then it's not just the FM Tuner, but other sources as well. Try resetting the microprocessor (p. 146 OM) and if still no joy, send it back and exchange it.
post #5 of 6
what setup of the receiver have you done? did the fm tuner tune to any stations... if not, you likely won't hear anything if the fm mute is active.
post #6 of 6
tuning to fm station is fine it works and I also did the reset may about 3 times, I connected a dvd player and the video from the dvd player works Im getting picture but no audio. although
the ipod does not mirror on the tv, but I could control the menus on the ipod using the denon remote.
