I'm in the process of designing and construction of a 2-way speaker system.
I'm using a Beyma 10BR60V2 woofer and a Tang Band 28-537SH tweeter.
The box will be sealed 2.7 cu. ft. The front baffle will have minimal surface area beyond
the outer circumference of each driver.
If the sealed box is made smaller than optimal (purposely) using WinISD to create a 3 db upslope as the Hz goes down,
Is that a sufficient way to overcome the baffle-step phenomenon?
Or can I use Mcacc to compensate for the Baffle-step phenomenon?
