Originally Posted by Chronoptimist
With a PC, the refresh rate is never exactly matched up to the framerate of the file, whether that is 23.976, 24.000 or something else. This means you have to choose between:
Both options 3 and 4 will give you smooth video playback and perfect audio sync.
I can't hear a difference when ReClock or VideoClock are working on the audio to keep it in sync, but I do see a difference when Smooth Motion is working.
ReClock and VideoClock also have the benefit of being able to play back 25p PAL content at the original 24p speed, so I prefer to use them.
All bitstreaming means, is that the audio is decoded from TrueHD/DTS-HD to PCM inside your amplifier. For ReClock/VideoClock to work, you just need to do that decoding inside the PC instead. (using LAV Audio) Audio quality is the same.
- Drop or repeat frames to keep audio in sync, which causes the video to stutter every so often.
- Don't allow the video to drop or repeat frames (smooth video) but let the audio drift out of sync.
- Use ReClock or VideoClock to resample the audio to keep perfect sync along with smooth video playback.
- Use madVR's Smooth Motion so that audio does not need resampled, but video frames are blended to maintain audio sync/video smoothness.
Well the motion was not as smooth for me using SMFRC but maybe the GT 430 isn't up to the task?
I don't mind dropping a frame to keep the audio in sync. I don't notice (sense) the audio not in sync or the video dropping a frame so it isn't an issue. If I heard or saw this issue I'd be more proactive about fixing it for sure. Statistics in madVR usually show one dropped frame on order of an hour or so.
I think that the DAC in my AVR is better than that in my PC so I prefer to let the audio device do the decoding or does this not matter as the DAC takes the audio when it is in it's LPCM form and converts it to digital at this point?
Stick to your custom 23Hz refresh rate and HD audio bitstreaming. You don't need madVR's SMFRC @60Hz refresh rate nor ReClock @23Hz refresh rate.
